[gdal-dev] OT: subversion configuration
Norman Vine nhv at cape.com
Fri Jul 25 13:22:24 EDT 2008
Ari Jolma writes:
> I'm annoyed because I can't configure subversion properly for
> my local
> copy of GDAL repository.
> I want to keep all files locally LF also in Windows. I've set
> [auto-props]
> *.* = svn:eol-style=LF
> in svn config. However, when I commit, the file is converted
> into CRLF
> and also when I update, the files are CRLF.
> Any help appreciated,
Ari,
AFAIK the easiest way to do this is to use the Cygwin tools
Your local SVN repository will need to be on a Unix Mount
 http://cygwin.com/cygwin-ug-net/using-textbinary.html
HTH
Norman
