[gdal-dev] GDAL in 64bits Linux environment
Limei Ran lran at unc.edu
Wed Jul 30 14:52:52 EDT 2008
Hi Mike:
Thanks for your reply and the following is my error:
libtool: link: creating GNU ld script: .libs/libgdal.la.lnkscript
libtool: link: g++ -shared -nostdlib
/usr/lib/gcc/x86_64-redhat-linux/4.1.2/../../../../lib64/crti.o
/usr/lib/gcc/x86_64-redhat-linux/4.1.2/crtbeginS.o
.libs/libgdal.la.lnkscript  -Wl,-rpath
-Wl,/nas/uncch/depts/cep/emc/lran/mims/mimssp_8_2008/src/libs/proj-4.6.0/local/lib
-Wl,-rpath
-L/nas/uncch/depts/cep/emc/lran/mims/mimssp_8_2008/src/libs/proj-4.6.0/local/lib
/nas/uncch/depts/cep/emc/lran/mims/mimssp_8_2008/src/libs/proj-4.6.0/local/lib/libproj.so
-lsqlite3 -L/usr/lib /usr/lib/libexpat.so -lgif -ljpeg -ltiff -lpng -lz
-lrt -ldl -L/usr/lib/gcc/x86_64-redhat-linux/4.1.2
-L/usr/lib/gcc/x86_64-redhat-linux/4.1.2/../../../../lib64
-L/lib/../lib64 -L/usr/lib/../lib64 -lstdc++ -lm -lc -lgcc_s
/usr/lib/gcc/x86_64-redhat-linux/4.1.2/crtendS.o
/usr/lib/gcc/x86_64-redhat-linux/4.1.2/../../../../lib64/crtn.o
-Wl,-soname -Wl,libgdal.so.1 -o .libs/libgdal.so.1.12.2
/usr/lib/libexpat.so: could not read symbols: File in wrong format
collect2: ld returned 1 exit status
make[1]: *** [libgdal.la] Error 1
make[1]: Leaving directory
`/nas/uncch/depts/cep/emc/lran/mims/mimssp_8_2008/src/libs/gdal-1.5.2'
make: *** [check-lib] Error 2
In the old 32bits environment, it worked fine.
Thanks,
Limei
Nidel, Mike wrote:
>I've gotten it to work using the 1.5 branch. I didn't have to do
>anything specific to 64-bit
>as far as I know. What are your errors?
>Mike
>>-----Original Message-----
>>From: gdal-dev-bounces at lists.osgeo.org
>>[mailto:gdal-dev-bounces at lists.osgeo.org] On Behalf Of Limei Ran
>>Sent: Wednesday, July 30, 2008 2:03 PM
>>To: gdal-dev at lists.osgeo.org
>>Subject: [gdal-dev] GDAL in 64bits Linux environment
>>Hi:
>>I am having some errors in compiling GDAL on our new 64bits
>>Linux server.  Could you tell me whether gdal1.5.2 has been
>>tested on 64bit Linux or what I need to change in the configure file?
>>Thanks,
>>Limei
>>_______________________________________________
>>gdal-dev mailing list
>>http://lists.osgeo.org/mailman/listinfo/gdal-dev
