[Gdal-dev] gdal_grid: Comments from a new player
Fodder cryan at csse.com.au
Mon Jun 2 19:20:09 EDT 2008
http://www.nabble.com/file/p17613002/gdalgrid.vrt gdalgrid.vrt
Hi Andrey,
I have attached the vrt file, the commandline, I have used is:
gdal_grid -a
invdist:power=2.0:smoothing=0.0:radius1=0.0:radius2=0.0:angle=0.0:max_points=0:min_points=0:nodata=-1000000000
-txe 322435.436500705 326982.517891606 -tye 6366087.01529708
6369483.98111739 -outsize 937 700 -of EHdr -ot Float32 -l gdalgrid
"gdalgrid.vrt" "rain_stations.flt"
The .hdr file that is created contains the tag 'ULYMAP
6366089.44170124' which seem to be creating problems for me since that is
the YMin coord for the grid.
Regarding the other issue, I think this was my mistake. I had a shapefile
with the same name in the directory and I guess GDAL was reading the
projection from it's .prj file.
Sorry also about reporting old bugs..., I am using the FWTools build of GDAL
with ECW/SID as I don't really want to get into commpiling my own versions
etc.
Andrey Kiselev wrote:
> I tried to reproduce these errors and did not succeeded. Could you be
> more specific how do you get them? I need a VRT file content and your
> command line options.
> Best regards,
> Andrey
> Andrey V. Kiselev
> ICQ# 26871517
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
View this message in context: http://www.nabble.com/gdal_grid%3A-Comments-from-a-new-player-tp17591913p17613002.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
