[gdal-dev] linking problem: cannot find frmts/o/.libs/aigccitt.o
Yann Chemin yann.chemin at gmail.com
Mon Jun 2 23:24:19 EDT 2008
Hello list,
I am a bit stuck here and would gladly have a piece of enlightenment...
I am trying to compile gdal on a computer, and somehow /usr/bin/ld
does not find a file that exists.
...puzzled
thanks for any help,
Yann
libtool: link: rm -fr  .libs/libgdal.la.lnkscript
libtool: link: creating GNU ld script: .libs/libgdal.la.lnkscript
libtool: link: g++ -shared -nostdlib /usr/lib/../lib64/crti.o
/usr/local/lib/gcc/x86_64-unknown-linux-gnu/4.2.4/crtbeginS.o
.libs/libgdal.la.lnkscript  -Wl,-rpath -Wl,/usr/lib64 -Wl,-rpath
-Wl,/usr/local/lib/../lib -Wl,-rpath -Wl,/usr/lib64 -Wl,-rpath
-Wl,/usr/local/lib/../lib -L/usr/lib64 -L/usr/local/lib
/usr/lib64/libexpat.so /usr/lib64/libjpeg.so -ltiff -lpng
-L/usr/local/pgsql/lib -lpq -lz -lrt -ldl
-L/usr/local/lib/gcc/x86_64-unknown-linux-gnu/4.2.4
-L/usr/local/lib/gcc/x86_64-unknown-linux-gnu/4.2.4/../../../../lib64
-L/lib/../lib64 -L/usr/lib/../lib64
/usr/local/lib/../lib/libstdc++.so
-L/export/home/ychemin/gcc/x86_64-unknown-linux-gnu/32/libstdc++-v3/src
-L/export/home/ychemin/gcc/x86_64-unknown-linux-gnu/32/libstdc++-v3/src/.libs
-L/export/home/ychemin/gcc/host-x86_64-unknown-linux-gnu/gcc/32
-L/usr/local/lib/../lib
-L/lib/../lib -L/usr/lib/../lib
-L/export/home/ychemin/gcc/host-x86_64-unknown-linux-gnu/gcc -lm -lc
-lgcc_s /usr/local/lib/gcc/x86_64-unknown-linux-gnu/4.2.4/crtendS.o
/usr/lib/../lib64/crtn.o        -Wl,-soname -Wl,libgdal.so.1 -o
.libs/libgdal.so.1.12.1
/usr/bin/ld: skipping incompatible
/export/home/ychemin/gdal-svn-stable-2008.05.22/frmts/o/.libs/aigccitt.o
when searching for
/usr/bin/ld: cannot find
collect2: ld returned 1 exit status
make[1]: *** [libgdal.la] Error 1
make[1]: Leaving directory `/export/home/ychemin/gdal-svn-stable-2008.05.22'
make: *** [check-lib] Error 2
Yann Chemin
International Rice Research Institute
Office: http://www.irri.org/gis
Perso: http://www.freewebs.com/ychemin
