[gdal-dev] gdal translate error converting ArcGRID binary to ASCII
Matt Wilkie matt.wilkie at gov.yk.ca
Wed Jun 4 17:52:04 EDT 2008
Hi Puneet,
No don't flatten the directories. ArcInfo expects a nested file
structure. The following example is for an Arcinfo binary grid called
"thegridname":
./log
./info/arc.dir
./info/arc0000.dat
./info/arc0000.nit
./info/arc0001.dat
./info/arc0001.nit
./thegridname/dblbnd.adf
./thegridname/hdr.adf
./thegridname/log
./thegridname/metadata.xml
./thegridname/prj.adf
./thegridname/sta.adf
./thegridname/vat.adf
./thegridname/w001001.adf
./thegridname/w001001x.adf
Some of the files are optional, and some are not used by gdal (the major
one being the 'info' directory and contents). You can pare the list down
to the following and gdal_translate will still work (though arcinfo will
not):
./thegridname/prj.adf        # optional but desired projection info
Based on your error message and example, the files were not created by
ArcInfo as in Arc grid names cannot start with a number (that said, gdal
doesn't care about that restriction). I would try renaming the files
like this and try again:
./76980974/dblbnd.adf
./76980974/prj.adf
./76980974/w001001.adf
./76980974/hdr.adf
./76980974/sta.adf
./76980974/w001001x.adf
cheers,
matt wilkie
Geographic Information,
Information Management and Technology,
Yukon Department of Environment
10 Burns Road * Whitehorse, Yukon * Y1A 4Y9
867-667-8133 Tel * 867-393-7003 Fax
http://environmentyukon.gov.yk.ca/geomatics/
P Kishor wrote:
> On 5/31/08, William Kyngesburye <woklist at kyngchaos.com> wrote:
>> On May 31, 2008, at 1:25 PM, P Kishor wrote:
>>> [01:45 PM] ~/Data/climate_change/cartagena_arcgrid$ ls
>> *.adf
>>> 76980974\76980974\dblbnd.adf*   76980974\76980974\prj.adf*
>>> 76980974\76980974\w001001.adf*
>>> 76980974\76980974\hdr.adf*      76980974\76980974\sta.adf*
>>> 76980974\76980974\w001001x.adf*
>>> [01:46 PM] ~/Data/climate_change/cartagena_arcgrid$
>> gdal_translate -of
>>> AAIGrid 76980974\\76980974\\w001001.adf out.grd
>>> ERROR 4: `76980974\76980974\w001001.adf' not recognised as a supported
>>> file format.
>>> GDALOpen failed - 4
>>> `76980974\76980974\w001001.adf' not recognised as a supported file format.
>>> I am on an Intel Macbook Pro with Mac OS X 10.5.3.
>>  One possibility is the backslashes - I see that often when downloading a
>> zip made on Windows and they expand into a flat file layout, but they
>> indicate a directory and file structure that GDAL may be expecting.  Try
>> removing the prefix of 'folders' from all the file names so it looks like:
>>  dblbnd.adf
>>  hdr.adf
>>  prj.adf
>>  sta.adf
>>  w001001.adf
>>  w001001x.adf
>>  and put it in a folder named '76980974'.
> I suspected as such, but instead of putting all of them in a single
> folder, I built a folder hierarchy as suggested by the back slashes (I
> am not really conversant with the ArcGRID file/folder structure).
> I will flatten the list and try it again.
> Thanks.
> Puneet.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
