[gdal-dev] NITF JPEG2000 read support?
Sven Geggus usenet at fuchsschwanzdomain.de
Thu Jun 5 11:14:46 EDT 2008
Dear gdal developers,
I am fiddeling with NITF JPEG2000 read support (with limited success so
far).
What is the current state of NITF JPEG2000 in gdal?
When trying to use jasper I get the following message:
> gdalinfo test_jpg2000.nsf
ERROR 4:
2K_SUBFILE:1070,40040,test_jpg2000.nsf' does not exist in the file system,
and is not recognised as a supported dataset name.
ERROR 1: Unable to open JPEG2000 image within NITF file.
Is the JP2KAK driver available?
gdalinfo failed - unable to open 'test_jpg2000.nsf'.
Using ecwj2 the I get a different message, but it still does not work:
ERROR 1: An error has occurred: Error 86 "File is invalid or corrupt"  file
"" line 0
Unfortunately I was unable to test with the kakadu library as I did not find
an evaluation Version.
Regards
Sven
"If you don't make lower-resolution mapping data publicly
available, there will be people with their cars and GPS
devices, driving around with their laptops" (Tim Berners-Lee)
/me is giggls at ircnet, http://sven.gegg.us/ on the Web
