[gdal-dev] Re: Byte swapping (esp for ENVI format output) & RSAT2 doc
Paul Mallas pmallas at rsmas.miami.edu
Fri Jun 6 09:47:09 EDT 2008
Get lost you loser.
Just wanted one response.
Paul Mallas wrote:
> Hello,
> Does any gdal utility (like gdal_translate) have the capacity to byte
> swap data, especially for the ENVI output format?  I have poked around a
> bit in the documents and the answer seems to be "no."  But byte swapping
> seems like something that some gdal utility should do.
> Also, the GDAL RS2 xml product page references RadarSat document
> RN-RP-51-27. I have hunted around the internet and not found it.  Is it
> available somewhere?
> Thanks,
> Paul
