[gdal-dev] Re: Byte swapping (esp for ENVI format output) & RSAT2doc
Paul Mallas pmallas at rsmas.miami.edu
Fri Jun 6 10:39:02 EDT 2008
Thanks to Shawn for the document.
I inadvertently posted a reply to myself - in a moment of silliness I
typed a reply to my post but did not mean to send it.
Sorry for the nonsense and the extra clutter.
Gong, Shawn (Contractor) wrote:
> hi Paul  and list,
> RadarSat document RN-RP-51-27 can be found at
> http://www.radarsat2.info/product/51-2713_-_RSAT-2_Product_Format_Defini
> tion_-_Iss1_7.pdf
> Shawn
> -----Original Message-----
> From: gdal-dev-bounces at lists.osgeo.org
> [mailto:gdal-dev-bounces at lists.osgeo.org] On Behalf Of Paul Mallas
> Sent: Friday, June 06, 2008 9:47 AM
> To: gdal-dev at lists.osgeo.org
> Subject: [gdal-dev] Re: Byte swapping (esp for ENVI format output) &
> RSAT2doc
> Get lost you loser.
> Just wanted one response.
> Paul Mallas wrote:
>> Hello,
>> Does any gdal utility (like gdal_translate) have the capacity to byte
>> swap data, especially for the ENVI output format?  I have poked around
> a
>> bit in the documents and the answer seems to be "no."  But byte
> swapping
>> seems like something that some gdal utility should do.
>> Also, the GDAL RS2 xml product page references RadarSat document
>> RN-RP-51-27. I have hunted around the internet and not found it.  Is
> it
>> available somewhere?
>> Thanks,
>> Paul
> gdal-dev mailing list
