[gdal-dev] Re: Byte swapping (esp for ENVI format output) & RSAT2 doc
Paul Mallas pmallas at rsmas.miami.edu
Fri Jun 6 12:09:45 EDT 2008
Thanks for the note - I went ahead and wrote a small c++ program to do
this.
Pretty easy to implement, but it seemed like something that would be in
the gdal utilities.
Christopher Barker wrote:
>> Paul Mallas wrote:
>>> Does any gdal utility (like gdal_translate) have the capacity to
>>> byte swap data, especially for the ENVI output format?
> I don't know if there is a way for GDAL to do it, but it would be a
> pretty short scrip tin python with numpy -- load the rasterband into a
> numpy array, byteswap it, then save it back.
> -Chris
