[gdal-dev] Correct way to create a new GTiff, with numpy.zeros() and python bindings
Dane Springmeyer blake at hailmail.net
Fri Jun 6 20:20:44 EDT 2008
Hi list,
Im just starting to use the python bindings and have been
experimenting with gdal_rasterize which great results, effectively
burning in multiple different colors based on some related vector
shapefile attributes.  The trick to getting started was that I did not
have any raster (at the right extent and resolution) to copy from, so
to get started I followed the api tutorial to create and new Gtiff.
This code works perfectly for my usecase:
from osgeo import gdal
from osgeo import osr
import numpy
driver = gdal.GetDriverByName('GTiff')
dst_ds = driver.Create( "/Users/spring/projects/wind/data/processed/
wpc_final.tif", 7850, 3500, 4, gdal.GDT_Byte)
dst_ds.SetGeoTransform( [-124.75, .001, 0.0, 49.02, 0.0, -.001] )
srs = osr.SpatialReference()
srs.ImportFromEPSG(4326)
dst_ds.SetProjection( srs.ExportToWkt() )
But the tutorial also has the step of writing zeros over the image
with numpy. Since I am already burning in the required values into my
raster with gdal_rasterize this seems not to matter, but I am really
curious for future uses how to get this step working. Starting with
zeros, or any default value would be useful.
So, if I execute the following code block next:
zeros = numpy.zeros( (7850, 3500) )
dst_ds.GetRasterBand(1).WriteArray( zeros )
dst_ds.GetRasterBand(2).WriteArray( zeros )
dst_ds.GetRasterBand(3).WriteArray( zeros )
dst_ds.GetRasterBand(4).WriteArray( zeros )
I get the error:
'ValueError: array larger than output file, or offset off edge'  which
obviously means that I am writing the wrong size numpy array into my
raster.
So, what do I need to know to figure out the right dimensions for the
numpy.zeros() function? Some slick fraction of my image size in pixels
and my geotransform?
Thanks,
Dane
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20080606/6a30e701/attachment-0001.html
