[gdal-dev] Excessive memory usage in python script
Mon Jun 9 15:34:48 EDT 2008
>   format = "GTiff"
>   outdataset.driver.Create(outfile, inband.XSize, inband.YSize, 1,
> gdal.GDT_Float32)
>   outband = outdataset.GetRasterBand(1)
Jamie,
I'm very suspicious about the above, and I *suspect* it is orphaning
the new dataset objects created with the Create() call which might
be responsible for your resource leak.
I would suggest:
   format = "GTiff"
   outdataset = gdal.GetDriverByName(format).Create(....)
Good luck,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
