[gdal-dev] Image values greater than the maximum.
Wed Jun 11 04:35:04 EDT 2008
Michele,
This is quite surprising. I'd appreciate your filing a detailed ticket
on the issue.
Best regards,
FrankW
On Wed, Jun 11, 2008 at 3:57 AM, Michele Sanges
<michele.sanges at otomelara.it> wrote:
> I noticed a problem in my code; it's reproducible with the
> Arc/Info_ASCII_GRID gdal dataset taken from:
> http://download.osgeo.org/gdal/data/aaigrid/095b_dem_90m.asc
> If I call the function GDALComputeRasterMinMax() with the second
> parameter 'bApproxOK' set to FALSE, I get the values:
> * min=213
> * max=538
> Then, when I go to read the image with the ReadIO function, all of the
> values are within this range and this is ok.
> Instead if I call the function GDALComputeRasterMinMax() with the second
> parameter 'bApproxOK' set to TRUE, I get the same above min and max
> values but when I go to read the image, some of the values are greater
> than the maximum.
> Why the parameter 'bApproxOK' has influence on the values of data?
> Thanks.
> Michele
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
and watch the world go round - Rush | Geospatial Programmer for Rent
