[Gdal-dev] c# Bindings in Mono/Linux
Evans, Frank fevans at harris.com
Wed Jun 11 14:24:35 EDT 2008
Tamas, thanks for the test-results link. I had read that tests were
passing, but the log-detail provided a lot of useful info. I will try
SWIG 1.3.31 this weekend, and let everyone know. I can't switch mono
versions, at least not easily. Are the library outputs for the automated
builds accessible?
I know I'm asking for speculation, but do you think there's a
32-bit/64-bit issue?
-----Original Message-----
From: Tamas Szekeres [mailto:szekerest at gmail.com]
Sent: Saturday, June 07, 2008 6:30 PM
To: Evans, Frank
Cc: gdal-dev at lists.osgeo.org
Subject: Re: [Gdal-dev] c# Bindings in Mono/Linux
I`ve just tried http://download.osgeo.org/gdal/gdal-1.5.2.tar.gz on my
debian AMD64 installation following your compile steps (the install
directory was different). After the successful build I had managed to
run `make test` in the /csharp directory without further hackings and
file copies. (the csharp related files .so .dll .config was in the
same directory where the application has been started)
However my mono and SWIG version are different:
szekerest at sirius:~$ swig -version
SWIG Version 1.3.31
Compiled with g++ [x86_64-unknown-linux-gnu]
Please see http://www.swig.org for reporting bugs and further
information
szekerest at sirius:~$ mcs --version
Mono C# compiler version 1.2.2.1
szekerest at sirius:~$ cat /proc/version
Linux version 2.6.18-5-amd64 (Debian 2.6.18.dfsg.1-13etch6)
(dannf at debian.org) (gcc version 4.1.2 20061115 (prerelease) (Debian
4.1.1-21)) #1 SMP Tue Dec 18 21:39:26 UTC 2007
FYI: The expected compile outputs and the `make test` results can be
inspected at the buildbot:
http://buildbot.osgeo.org:8500/waterfall
Best regards,
Tamas
2008/6/7 fevans <fevans at harris.com>:
> This message captures my unsuccessful attempts to get c# bindings to
work
> under mono/Linux.
> Hopefully it will help someone else.
> IMPORTANT: If your like me, you're quickly scanning the web looking
for a
> solution. This is not a solution. It is a snapshot of what was tried,
and
> what didn't work.
> These attempts were made with the following sources
> http://download.osgeo.org/gdal/gdal-1.5.1.tar.gz
> Environment:
> Mono Rev:       1.9.1
> Linux:          2.6.9-67.0.15.ELsmp x86_64 x86_64 x86_64 GNU/Linux
> Swig:           1.3.35
> Reference Discussion Threads:
> In investigating the possibility that this was a 32-bit v.s. 64-bit
issue, I
> found the following threads.
> (Linux 64)
> http://lists.osgeo.org/pipermail/gdal-dev/2005-October/006838.html
> (Linux 64)
http://lists.osgeo.org/pipermail/mapserver-users/2006-November/020562.ht
ml
> (Windows 64)
http://article.gmane.org/gmane.comp.gis.gdal.devel/14807
> Attachment Descriptions:
> gdal1.5.2.configuration.log     Contains the output of the ./configure
command.
> gdal1.5.2.build.log             Contains the output of the build.
> gdal1.5.2.build.warnings.log    Summary of warnings produced by build.
> mono.shlib.cop.gdal_wrap.log     Run 'mono-shlib-cop gdal_csharp.dll'
> Build Procedures:
> ./configure --without-libtool
--prefix=/ssa/users/fevans/apps/gdal-1.5.2
> make >& gdal1.5.2.build.log &
> cd swig
> make
> cd csharp
> make
> cd $GDAL_SRC_ROOT
> make install
> export PATH="/ssa/users/fevans/apps/gdal-1.5.2/bin:$PATH"
> export
LD_LIBRARY_PATH="/ssa/users/fevans/apps/gdal-1.5.2/lib:$LD_LIBRARY_PATH"
> Required Modifications
> There is an error in "swig/csharp/GNUmakefile"
> Change line 50 from :   echo "<dllmap dll=\""$*"_wrap\"
target=\""$@"\" >" >>
> $*_csharp.dll.config
>                          To:   echo "<dllmap dll=\""$*"_wrap\"
> target=\""$@"\" />" >> $*_csharp.dll.config
> Other things Tried
> 1. Copy bindings to gdal install location. The makefile doesn't do
this.
> After swig/csharp make test failed, I tried numerous things without
success.
>  - Copy all exes and libs from swig/csharp to $GDAL_HOME/bin or
> $GDAL_HOME/lib
>  - In addition copy *.dll, *.dll.config to $GDAL_HOME/bin
> export GDAL_DATA=/ssa/users/fevans/apps/gdal-1.5.2/share/gdal
> export
> cd $GDAL_HOME/bin
> mono ./GDALInfo.exe /tmp/anImage.tif
> Application error: An exception was thrown by the type initializer for
> OSGeo.GDAL.Gdal
> mono --verbose   ./GDALInfo.exe /tmp/anImage.tif >
GDALInfo.exe.stacktrace
> 2. Modify Gdalmake.opt.in to use lib64.
>   This didn't help.
> Rename the libraries-Tried modifying the dll.config "dllmap" entries.
For
> example, change "libgdalcsharp.so" to "libgdal_wrap.so"
> -Tried the renaming the libgdalcsharp.so libraries.
> -Tried renaming the libraries as described in the previous steps, but
did it
> in the GNUMakefile, and rebuilt.
> Setting MONO_PATH
> Didn't help.
> Modify the csharp.opt file
> This didn't help me. But I'm wondering if the MONO=YES variable needs
to be
> set in Linux.
> I tried it both ways, without success.
> #Uncomment the following line if you want to compile with MONO on
windows
> #MONO = YES
> #Comment the following line out if you want to link against the gdal
dll
> #CSHARP_STATIC_LINKAGE = YES
> http://www.nabble.com/file/p17709337/gdal1.5.2.configuration.log
> http://www.nabble.com/file/p17709337/gdal1.5.2.build.log
gdal1.5.2.build.log
> http://www.nabble.com/file/p17709337/gdal1.5.2.build.warnings.log
> http://www.nabble.com/file/p17709337/gdal1.5.2.make.install.log
> http://www.nabble.com/file/p17709337/gdal1.5.2.swig.build.log
> http://www.nabble.com/file/p17709337/gdal1.5.2.swig.build.warnings.log
http://www.nabble.com/file/p17709337/gdal1.5.2.swig.csharp.make.test.log
> http://www.nabble.com/file/p17709337/GDALInfo.exe.stacktrace
> http://www.nabble.com/file/p17709337/mono.shlib.cop.gdal_wrap.log
http://www.nabble.com/c--Bindings-in-Mono-Linux-tp17709337p17709337.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
