[gdal-dev] osm xml and everything else
Martin Daly Martin.Daly at cadcorp.com
Thu Jun 12 02:59:35 EDT 2008
> I understand there was talk about an ogr-osm driver.  Did it ever get
> anywhere?  If so, what state is it in?  If not, what is the current
> recommended route to getting data between osm and everything else?
I'm
> wanting to take snippets of osm xml and in the first instance, put it
in
> kml.  Ultimately, I'm wanting it in postgis where I can make real use
of
> it.  I'd also like to be able to easily suck new data out of postgis
> into something osm can use.  Recommendations?
http://svn.openstreetmap.org/applications/utils/export/
http://svn.openstreetmap.org/applications/utils/export/osm2kml/
http://svn.openstreetmap.org/applications/utils/export/osm2pgsql/
http://svn.openstreetmap.org/applications/utils/import/
M
