[gdal-dev] Using the CORINE2000 land cover/land use data base with GRASS-GIS under Ubuntu-linux 8.04
Nikos Alexandris nikos.alexandris at felis.uni-freiburg.de
Mon Jun 16 11:38:38 EDT 2008
On Sun, 2008-05-18 at 10:49 +0200, Nikos Alexandris wrote:
I would like to thank Mr. Silver and Mr. Zachariadis for their comments
upon the first version of the CORINE with GRASS tutorial.
The new corrected/re-styled document replaced the first "bad-looking"
version and is to be found in the same web-link as before:
http://www.isprs-studentconsortium.org/assets/files/Material_reports/Volume_2_No2/CORINE_withGRASS.pdf
Thank you,
Nikos
