[gdal-dev] AAIGrid decimal precision
Volker Wichmann Volker.Wichmann at uibk.ac.at
Wed Jun 18 05:03:08 EDT 2008
I have the following problem: the format of my data is originally
arc/info ascii with two decimals (e.g. 1002.35). For processing, I need
to use/convert to GeoTiff (Float32). And in the end, I use
gdal_translate to write the processed data again as arc/info ascii. But
now there are over 10 decimals written (e.g. 2003.73324423545) which
causes the file to take about twice the size of the original raster.
so my question is actually if there is any control on the decimal
precision written to ascii files? I see that the AAIGrid driver uses "
%6.20g" for printing, so I could patch this. But it would be nicer to
have a feature like a driver creation option to specify the number of
decimals desired.
any help is appreciated,
thanks,
Volker
