[gdal-dev] AAIGrid decimal precision
Wed Jun 18 11:04:36 EDT 2008
Volker Wichmann wrote:
> Hi,
> I have the following problem: the format of my data is originally
> arc/info ascii with two decimals (e.g. 1002.35). For processing, I need
> to use/convert to GeoTiff (Float32). And in the end, I use
> gdal_translate to write the processed data again as arc/info ascii. But
> now there are over 10 decimals written (e.g. 2003.73324423545) which
> causes the file to take about twice the size of the original raster.
> so my question is actually if there is any control on the decimal
> precision written to ascii files? I see that the AAIGrid driver uses "
> %6.20g" for printing, so I could patch this. But it would be nicer to
> have a feature like a driver creation option to specify the number of
> decimals desired.
Volker,
I would encourage you to file an enhancement request for this.  It would
be quite easily to add some sort of precision control creation option.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
