[gdal-dev] Problems compiling GDAL 1.5.1
Bill Thoen bthoen at gisnet.com
Wed Jun 18 19:12:16 EDT 2008
I ran into a problem compiling GDAL 1.5.1 on my Linux Fedora Core 9
system. The error seems to be caused by max and min macros with the
wrong number of parameters. Anyone else run into this and what's the fix?
Below is the relevant section of the log that reported this:
/bin/sh /home/bthoen/Install/gdal-1.5.1/libtool --mode=compile --tag=CXX
g++ -g -O2  -Wall  -I. -I.. -I../..
-I/home/bthoen/Install/gdal-1.5.1/port
-I/home/bthoen/Install/gdal-1.5.1/gcore
-I/home/bthoen/Install/gdal-1.5.1/alg
-I/home/bthoen/Install/gdal-1.5.1/ogr
-I/home/bthoen/Install/gdal-1.5.1/ogr/ogrsf_frmts -DOGR_ENABLED
-I/home/bthoen/Install/gdal-1.5.1/port  -c -o ../o/ogrgeojsonlayer.o
ogrgeojsonlayer.cpp
libtool: compile:  g++ -g -O2 -Wall -I. -I.. -I../..
-I/home/bthoen/Install/gdal-1.5.1/port -c ogrgeojsonlayer.cpp  -fPIC
-DPIC -o ../o/.libs/ogrgeojsonlayer.o
In file included from
/usr/lib/gcc/i386-redhat-linux/4.3.0/../../../../include/c++/4.3.0/bits/stl_algo.h:66,
                 from
/usr/lib/gcc/i386-redhat-linux/4.3.0/../../../../include/c++/4.3.0/algorithm:67,
                 from ogrgeojsonlayer.cpp:32:
/usr/lib/gcc/i386-redhat-linux/4.3.0/../../../../include/c++/4.3.0/bits/algorithmfwd.h:248:41:
error: macro "max" passed 3 arguments, but takes just 2
/usr/lib/gcc/i386-redhat-linux/4.3.0/../../../../include/c++/4.3.0/bits/algorithmfwd.h:259:41:
error: macro "min" passed 3 arguments, but takes just 2
                 from
/usr/lib/gcc/i386-redhat-linux/4.3.0/../../../../include/c++/4.3.0/bits/algorithmfwd.h:244:
error: expected unqualified-id before 'const'
error: expected `)' before 'const'
error: expected initializer before 'const'
error: template declaration of 'const _Tp& std::max'
/usr/lib/gcc/i386-redhat-linux/4.3.0/../../../../include/c++/4.3.0/bits/algorithmfwd.h:255:
error: template declaration of 'const _Tp& std::min'
In function 'void std::__merge_sort_loop(_RandomAccessIterator1,
_RandomAccessIterator1, _RandomAccessIterator2, _Distance)':
/usr/lib/gcc/i386-redhat-linux/4.3.0/../../../../include/c++/4.3.0/bits/stl_algo.h:2884:
error: expected unqualified-id before '(' token
_RandomAccessIterator1, _RandomAccessIterator2, _Distance, _Compare)':
/usr/lib/gcc/i386-redhat-linux/4.3.0/../../../../include/c++/4.3.0/bits/stl_algo.h:2908:
ogrgeojsonlayer.cpp: In member function 'void
OGRGeoJSONLayer::DetectGeometryType()':
ogrgeojsonlayer.cpp:377: warning: unused variable 'lyrType'
make[3]: *** [../o/ogrgeojsonlayer.o] Error 1
make[3]: Leaving directory
`/home/bthoen/Install/gdal-1.5.1/ogr/ogrsf_frmts/geojson'
make[2]: *** [geojson-target] Error 2
make[2]: Leaving directory `/home/bthoen/Install/gdal-1.5.1/ogr/ogrsf_frmts'
make[1]: *** [sublibs] Error 2
make[1]: Leaving directory `/home/bthoen/Install/gdal-1.5.1/ogr'
make: *** [ogr-target] Error 2
