[gdal-dev] Urgent GDal failing to open a file.
Fri Jun 20 19:22:50 EDT 2008
Courtney Schitka wrote:
> And I was hoping for an easy solution with FWTools or something...
> Thanks for the suggestions boys. Looks like I've got a long night a head
> of me.
Courtney,
You can assign a coordinate system as part of a dataset copy using
the gdal_translate command like this:
   gdal_translate -a_srs abc.wkt in.tif out.tif
Assuming in.wkt contains the well known text coordinate system definition.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
