[gdal-dev] Re: GDAL Translate to remove SRS
Courtney Schitka c.schitka at gmail.com
Sun Jun 22 09:59:27 EDT 2008
-Jukka,
Well the file is already geo-referenced so I am not trying to add
geo-referencing to it. I am trying to remove the SRS from it. So I was
hoping that by using gdal_translate -a_srs (EMPTY WKT here). I was hoping
that someone could tell me what I needed to put in for a WKT to make the SRS
appear to be empty.
Thanks
Courtney
On Sat, Jun 21, 2008 at 6:26 PM, Jukka Rahkonen <jukka.rahkonen at mmmtike.fi>
wrote:
> Courtney Schitka <c.schitka <at> gmail.com> writes:
> > Can I use gdal_translate to remove an existing SRS in a geotiff and
> replace it
> with an empty one by specifying -a_srs (WHATEVER it is for an empty wkt).
> If so
> what is the wkt format I need to specify for an empty SRSThanks Court
> Hi,
> Would you be satisfied with a normal tiff image + world file for
> georefencing?
> That is achieved by
> gdal_translate -of GTiff -co profile=baseline -co tfw=yes
> I have needed that sometimes for cleaning geotiff images containing wrong
> tags,
> for example units in fathoms instead of meters.
> -Jukka Rahkonen-
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20080622/beffb3dd/attachment-0001.html
