[gdal-dev] TILED=NO creates a tiled TIFF?
Sun Jun 22 17:47:41 EDT 2008
Maciej Sieczka wrote:
> Hi!
> I have a tiled GeoTIFF at input:
> $ gdalinfo ~/check.tif | grep Block
> Band 1 Block=256x256 Type=Byte, ColorInterp=Palette
> I want to make it stripped, yet the output of:
> $ gdal_translate -co "TILED=NO" check.tif check2.tif
> seems still tiled:
> $ gdalinfo ~/check2.tif | grep Block
> Band 1 Block=4090x2 Type=Byte, ColorInterp=Palette
> I expected "Block=WIDTHx1". Is there something wrong or my bad?
Maciej,
The traditional TIFF logic is to create strips which are 8K or so.  If
you want each strip to be a single scanline, try also specifying
-co BLOCKYSIZE=1.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
