[gdal-dev] TILED=NO creates a tiled TIFF?
Mon Jun 23 13:03:08 EDT 2008
Maciej Sieczka wrote:
> Frank Warmerdam pisze:
>>> Thanks for the hint. Unfortunatelly gdal_translate segfaults then:
>>> Starting program: /usr/local/bin/gdal_translate -co "TILED=YES" -co
>>> "BLOCKYSIZE=1" check.tif check3.tif
>> It appears you switched back to TILED=YES from TILED=NO.
> Sorry! It was late.
>> A blockysize of
>> 1 is not legal for tiled files.  I'm not sure why things crashed though.
>> You might want to file a ticket on that aspect.
> Will do.
>> But try:
>> gdal_translate -co TILED=NO -co BLOCKYSIZE=1 check.tif check3.tif
> Seems to work, but throws out an error:
> $ gdal_translate -co "TILED=NO" -co "BLOCKYSIZE=1" check.tif check3.tif
> Input file size is 4090, 2216
> ERROR 1: TIFFReadDirectory:Cannot handle zero number of tiles
> 0...10...20...30...40...50...60...70...80...90...100 - done.
> Is everything OK?
Maciek,
Strange, I do not see the same behavior:
warmerda at gdal64[13]% gdal_translate -co TILED=NO -co BLOCKYSIZE=1 utm.tif
out.tif --debug off
Input file size is 512, 512
The error message is concerning to me, but it is hard to know if things
worked or not.  Viewing the resulting file, and inspecting a tiffinfo
report on it would be helpful.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
