[gdal-dev] a complete list of GDAL supported EPSG codes
Wed Jun 25 11:08:58 EDT 2008
Maciej Sieczka wrote:
> Frank Warmerdam pisze:
>> 900913 is not really an EPSG code.
> Yes I know.
>> Do you want real EPSG codes or also every other crappy thing someone
>> has pushed into the EPSG name space for some special purpose?
> The latter. Ie. all the codes that epsg_tr.py is able to process - like
> the 900913.
Maciej,
There is no uniform mechanism to accomplish this.  You can just give epsg_tr.py
a wide numeric range and it will try everything in the range but it will likely
take an inordinate amount of time.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
