[gdal-dev] Attempt to read past EOF ... dtm000082/../info/arc.dir
Markus Neteler neteler at osgeo.org
Mon Jun 30 08:40:26 EDT 2008
I have received a set of (official governmental) DTM files which all
report subsequent errors:
gdalinfo /home/neteler/data/DTM_wgs84_orto_grd/B_1mX1m/dtm000082
ERROR 3: Attempt to read past EOF in
/home/neteler/data/DTM_wgs84_orto_grd/B_1mX1m/dtm000082/../info/arc.dir.
ERROR 4: Failed to open table dtm000082.VAT
Driver: AIG/Arc/Info Binary Grid
Files: /home/neteler/data/DTM_wgs84_orto_grd/B_1mX1m/dtm000082
       /home/neteler/data/DTM_wgs84_orto_grd/B_1mX1m/dtm000082/log
       /home/neteler/data/DTM_wgs84_orto_grd/B_1mX1m/dtm000082/w001001.adf
       /home/neteler/data/DTM_wgs84_orto_grd/B_1mX1m/dtm000082/dblbnd.adf
       /home/neteler/data/DTM_wgs84_orto_grd/B_1mX1m/dtm000082/w001001x.adf
       /home/neteler/data/DTM_wgs84_orto_grd/B_1mX1m/dtm000082/sta.adf
       /home/neteler/data/DTM_wgs84_orto_grd/B_1mX1m/dtm000082/hdr.adf
Size is 2000, 2000
Coordinate System is `'
Origin = (666000.000000000000000,5148000.000000000000000)
Pixel Size = (1.000000000000000,-1.000000000000000)
Corner Coordinates:
Upper Left  (  666000.000, 5148000.000)
Lower Left  (  666000.000, 5146000.000)
Upper Right (  668000.000, 5148000.000)
Lower Right (  668000.000, 5146000.000)
Center      (  667000.000, 5147000.000)
Band 1 Block=500x4 Type=Float32, ColorInterp=Undefined
  Min=1046.885 Max=1489.255
  NoData Value=-3.4028234663852886e+38
ls /home/neteler/data/DTM_wgs84_orto_grd/B_1mX1m/dtm000082
dblbnd.adf  hdr.adf  log  sta.adf  w001001.adf  w001001x.adf
GDAL is luckily able to extract the data anyway but it doesn't look well.
My question is if this could be a GDAL problem or rather a broken
data set (I have 1750 of them). Before notifying them I want  to be sure
that GDAL operates ok.
thanks,
Markus
