[gdal-dev] GDAL & WMS
Even Rouault even.rouault at mines-paris.org
Mon Jun 30 17:18:36 EDT 2008
I've noticed that too and I think the problem is on the server side. The wms_4
test from GDAL autotest takes a big amount of time before failing : the
returned image from the NASA JPL server is 0 byte length.
Here's the culprit WMS request :
http://onearth.jpl.nasa.gov/wms.cgi?request=GetMap&version=1.1.1&layers=modis,global_mosaic&styles=&srs=EPSG:4326&format=image/jpeg&width=1024&height=1024&bbox=-180.00000000,89.86175997,-179.86175997,90.00000000
If you modify it to only return the global_mosaic layer, the request returns
in a few seconds, but the image is totaly black (probably OK for that part of
the world ?).
Le Monday 30 June 2008 23:10:01 Courtney Schitka, vous avez écrit :
> Has anyone noticed a huge performance issue with GDAL and WMS lately ? I've
> noticed a HUGE problems using the NASA JPL servers lately as in I can't
> seem to get data from them or anything. GDAL hasn't been rebuilt recompiled
> and the client code I am using hasn't changed at all either.
> Cheers
> Courtney
