[gdal-dev] The proj.dll mistery
Joaquim Luis jluis at ualg.pt
Mon Jun 30 20:11:00 EDT 2008
Martin Chapman wrote:
> Joaquim,
> I apologize that VantagePoint caused a problem for you.  We will make the
> fix to the install and get the proj.dll out of the system32 directory.  Our
> problem was that after upgrading to gdal 1.5x we could not get the proj dll
> to load if it wasn't in the path and the only path it would work with was
> the system32.
> Sorry again,
> Martin
Martin,
Don't feel particularly guilty. Many softwares do so. The real guilty
one is Bill that let codes install in the core system directories.
Joaquim
