[gdal-dev] The proj.dll mistery
Martin Chapman mchapman at texelinc.com
Mon Jun 30 20:32:22 EDT 2008
Joaquim,
Thank you for not being harsh.  It's wrong though because it causes major
headaches as you pointed out.  For what it's worth, I have made the change
and will post it tomorrow so others don't incur the same issue.
Thanks again,
Martin
-----Original Message-----
Sent: Monday, June 30, 2008 6:11 PM
To: Martin Chapman
Cc: gdal-dev at lists.osgeo.org
Subject: Re: [gdal-dev] The proj.dll mistery
Martin Chapman wrote:
> Joaquim,
> I apologize that VantagePoint caused a problem for you.  We will make the
> fix to the install and get the proj.dll out of the system32 directory.
Our
> problem was that after upgrading to gdal 1.5x we could not get the proj
dll
> to load if it wasn't in the path and the only path it would work with was
> the system32.
> Sorry again,
> Martin
Martin,
Don't feel particularly guilty. Many softwares do so. The real guilty
one is Bill that let codes install in the core system directories.
Joaquim
