[gdal-dev] Re: gdalwarp -co COMPRESSION issues
Jukka Rahkonen jukka.rahkonen at mmmtike.fi
Mon Mar 3 00:21:38 EST 2008
Maciej Sieczka <tutey <at> o2.pl> writes:
> Moreover, if the input file is big enough for gdalwarp with compression
> to try creating 4GB+ raster, it corrupts the output, yielding errors:
> TIFFAppendToStrip:Maximum TIFF file size exceeded
> ERROR 1: TIFFAppendToStrip:Maximum TIFF file size exceeded
> ERROR 1: TIFFWriteEncodedStrip() failed.
> which I guess should not happen, since BigTIFF is enabled - at configure
> I have: "LIBTIFF support: internal (BigTIFF=yes)".
About BigTIFF, I guess that the error will perhaps not happen if you ask
gdalwarp to use it by adding -co BigTIFF=yes.
-Jukka Rahkonen-
