[Gdal-dev] How to read geotiff file using GDAL
mchapman at texelinc.com mchapman at texelinc.com
Tue Mar 4 10:52:40 EST 2008
If you look carefully at www.gdal.org you will find many helpful tutorials that will show you how to open and examine a tif file.  The methods to open and deal with imagery are the same for all image types.  Meaning, you open an erdas imagine file the same way you open a geotiff.
Martin
Sent via BlackBerry by AT&T
-----Original Message-----
Date: Tue, 4 Mar 2008 06:49:34
To:gdal-dev at lists.osgeo.org
Subject: Re: [Gdal-dev] How to read geotiff file using GDAL
Thanks For reply Frank...........
But I am confused how this will happen..........
I didn't found any code on net which shows how to read the geotiff files and
extract information from it.......
Can u help me in regarding how to read .tif extension files and extracting
information.
If any link you can provide me then it will be very helpful............
Thanks a lot..........
Frank Warmerdam-2 wrote:
> bargi wrote:
>> Hi,
>> How can I read geotiff file format using GDAL
> Bargi,
> Yes, you can read GeoTIFF with GDAL.  This should be fairly evident from
> the "Supported Formats" list on the web site.
>>  and can I convert them to
>> shapfile format ???
> Generally GDAL does not support creating vector formats from raster
> formats, though there is a program in gdal/apps for generating contours
> in vector formats from elevation type data in raster formats.
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam,
> warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | President OSGeo, http://osgeo.org
> gdal-dev mailing list
Quoted from:
http://www.nabble.com/How-to-read-geotiff-file-using-GDAL-tp15820963p15826907.html
> bargi wrote:
>> Hi,
> Bargi,
>> shapfile format ???
> Best regards,
View this message in context: http://www.nabble.com/How-to-read-geotiff-file-using-GDAL-tp15820963p15828795.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
