[gdal-dev] ogr2ogr and GPX files
Dylan Beaudette dylan.beaudette at gmail.com
Tue Mar 4 17:03:17 EST 2008
On Tuesday 04 March 2008, Tamas Szekeres wrote:
> Hi,
> Yes, you should try with the recent SVN version. The changes related
> to this issue are pretty new.
> Best regards,
> Tamas
Hi Tamas,
Thanks for the tip. Unfortunately, even with today's SVN, I still get the same
error:
ERROR 1: SQL: Missing comma after column cat in SELECT statement.
Cheers,
Dylan
> 2008/3/4, Dylan Beaudette <dylan.beaudette at gmail.com>:
> > On Monday 03 March 2008, Even Rouault wrote:
> >  > In fact, using the same principle, you can use just one command line
> >  > and no intermediary file :
> >  > ogr2ogr -f GPX destination.gpx source.shp -sql "SELECT  src_field_1 AS
> >  > name, src_field_2 AS desc FROM your_source_layer_name"
> >  > Thanks to FrankW for the tip ;-)
> > Thanks Even / Frank.
> >  One small problem:
> >  ogr2ogr -t_srs '+proj=latlong +datum=WGS84' \
> >  -f GPX -dsco GPX_USE_EXTENSIONS=YES \
> > veg_points.gpx veg_points.shp \
> >  -sql "SELECT cat AS foo FROM veg_points"
> >  Could this be a bug or my version of GDAL too old ? This is with GDAL
> > SVN, checked out a couple of weeks ago.
> >  I get a valid GPX file if I do not use the "AS foo" operator.
> >  Ideas?
> >  Dylan
> >  > Le Monday 03 March 2008 19:43:12 Even Rouault, vous avez écrit :
> >  > > Hi,
> >  > > I see your point...
> >  > > The solution is the powerful OGR Virtual Dataset format !
> >  > > See http://www.gdal.org/ogr/drv_vrt.html
> >  > > In fact, the documentation should probably be extended to
> >  > > demonstrate the power of the OGR SQL for that particular case
> >  > > Try to paste the following lines in a file (remapped_layer.vrt would
> >  > > be fine)
> >  > > <OGRVRTDataSource>
> >  > >     <OGRVRTLayer name="remapped_layer">
> >  > >         <SrcDataSource>your_source.shp</SrcDataSource>
> >  > >         <SrcSQL>SELECT src_field_1 AS name, src_field_2 AS desc FROM
> >  > > your_source_layer_name</SrcSQL>
> >  > >     </OGRVRTLayer>
> >  > > </OGRVRTDataSource>
> >  > > Replace your_source.shp, src_field_1, src_field_2 and
> >  > > your_source_layer_name by the appropriate values from your source
> >  > > dataset and 'ogrinfo -ro -al remapped_layer.vrt' should show a
> >  > > structure compatible of a GPX file.
> >  > > Best regards,
> >  > > Even
> >  > > Le Monday 03 March 2008 07:04:41 Dylan Beaudette, vous avez écrit :
> >  > > > Hi,
> >  > > > is there a simple approach (via ogr2ogr) to create GPS files which
> >  > > > have standard waypoint tags such as <name>, <elev>, <cmt>, etc. by
> >  > > > re-mapping columns in the attribute table of the source vector?
> >  > > > for example:
> >  > > > # export points vector from GRASS
> >  > > > v.out.ogr in=wp type=point dsn=wp.shp
> >  > > > # convert tp GPX:
> >  > > > wp_gps.gpx wp.shp
> >  > > > This results in a working GPX waypoints file, that when uploaded
> >  > > > to a GPS is functional, but the waypoints are all re-named
> >  > > > sequentially. Note that I am uploading the GPX file the GPS via
> >  > > > gpsbabel.
> >  > > > Does anyone know of the appropriate incantation that one could use
> >  > > > to translate the column structure of the input wp.shp (i.e. the
> >  > > > stuff in its .dbf) into standard waypoint tags?
> >  > > > thanks in advance!
> >  > > > PS: trying to write a simple tutorial for some colleagues [1]
> >  > > > 1. http://casoilresource.lawr.ucdavis.edu/drupal/node/553
> >  > > _______________________________________________
> >  > > gdal-dev mailing list
> >  > > gdal-dev at lists.osgeo.org
> >  > > http://lists.osgeo.org/mailman/listinfo/gdal-dev
> >  Dylan Beaudette
> >  Soil Resource Laboratory
> > University of California at Davis
> >  530.754.7341
Dylan Beaudette
530.754.7341
