[Gdal-dev] How to read geotiff file using GDAL
bargi bhagwat.maimt at gmail.com
Wed Mar 5 02:57:58 EST 2008
 Thank to u all for replying !!!!
  Yeah Jukka, is right .... I want to fetch information from geotiff files
and render that file in our project......
  I can't do it directly .......... That's why I am looking for the way to
do it.
  With your help I am able to read and fetch information.....but I am not
clear how to use this information to
  to render the file......???????
 Can anybody help me regarding this........
 Thanks
Jukka Rahkonen wrote:
> bargi <bhagwat.maimt <at> gmail.com> writes:
>> Hi,
>> How can I read geotiff file format using GDAL  and can I convert them to
>> shapfile format ???
> People are guessing wildly what you actually want.  My guess is that
> perhaps you
>  want to read the georeferencing info from geotiff and write a
> corresponding
> ESRI world file in order to use the image with some software not
> supporting
> geotiffs.  If this is the case then reading goes simply with gdalinfo
> utility,
> but I do not know if it is possible to write our the world file only.
> I am sure you would get better answers with a bit less mysterious
> questions.
> -Jukka Rahkonen.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
View this message in context: http://www.nabble.com/How-to-read-geotiff-file-using-GDAL-tp15820963p15844975.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
