[gdal-dev] Reprojection of HDF data.. again on GCP extraction
mattia mattia.parigiani at gmail.com
Wed Mar 5 10:41:34 EST 2008
Hello folks,
I still need some help / advise for reprojecting my HDF raster image
datasets..
I manage to dump the "Latitude" and "Longitude" data sets of the HDF file
into ASCII format...
Now I would like to use this data to do the reprojection.. The dump I did
using HDF's hdp utility as follows:
mattia at mattia-laptop:~/Desktop/data/prove/1$ hdp dumpsds -n Latitude -d -x
-o latitude AMOD021KM20070104035343.hdf
mattia at mattia-laptop:~/Desktop/data/prove/1$ hdp dumpsds -n Longitude -d -x
-o longitude AMOD021KM20070104035343.hdf
The contents of the file is as follows (Latitude for example):
64.731689 64.741600 64.749550 64.755737 64.760345 64.763504 64.765366
64.766037 64.765633 64.764244 64.761963 64.758858 64.754997 64.750458
64.745285 64.739532 64.733253 64.726479 64.719261 64.711617 64.703606
64.695229 64.686531 64.677536 64.668266 64.658737 64.648972 64.638985
64.628799 64.618423 64.607880 64.597176 64.586319 64.575333 64.564217
64.552979 64.541634 64.530190 64.518654 64.507034 64.495338 64.483559
64.471718 64.459816 64.447853 64.435837 64.423767 64.411659 64.399506
64.387314 64.375084 64.362823 64.350525 64.338203 64.325851 64.313484
64.301086 64.288673 64.276237 64.263779 64.251312 64.238823 64.226318
64.213806 64.201271 64.188736 64.176178 64.163612 64.151039 64.138451
64.125854 64.113251 64.100639 64.088013 64.075378 64.062737 64.050079
64.037415 64.024742 64.012062 63.999371 63.986668 63.973953 63.961227
63.948494 63.935745 63.922985 63.910213 63.897430 63.884628 63.871819
63.858990 63.846146 63.833290 63.820412 63.807522 63.794609 63.781685
63.768738 63.755768 63.742779 63.729767 63.716736 63.703678 63.690601
63.677494 63.664364 63.651207 63.638020 63.624805 63.611561 63.598286
63.584984 63.571644 63.558270 63.544861 63.531418 63.517937 63.504421
63.490864 63.477264 63.463623 63.449940 63.436214 63.422440 63.408619
63.394753 63.380836 63.366871 63.352848 63.338776 63.324650 63.310463
63.296223 63.281918 63.267559 63.253132 63.238644 63.224091 63.209465
63.194775 63.180012 63.165180 63.150269 63.135284 63.120224 63.105080
63.089855 63.074547 63.059151 63.043671 63.028099 63.012436 62.996674
62.980820 62.964863 62.948811 62.932648 62.916386 62.900009 62.883526
62.866928 62.850208 62.833378 62.816418 62.799339 62.782131 62.764790
62.747314 62.729702 62.711952 62.694057 62.676014 62.657822 62.639477
62.620972 62.602303 62.583473 62.564472 62.545296 62.525944 62.506409
62.486687 62.466774 62.446667 62.426357 62.405842 62.385117 62.364174
etc
Now, I need to construct GCPs from this data and I would just like to know
what would be best..
1) writing a C utility which does the job and prepares GCPs which later I
can pass to gdal_translate from a file for example
2) A C utility which creates the GCPs and a VRT file with these included for
the later coming reprojection
Any other ideas would be appreciated..
The problem is though how to assign the actual GCPs...  I mean, every GCP
has format (x,y) > (lat,long) ..   how do I know how to assign the (x,y)
part??
Regards
Mattia
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20080305/54d28d33/attachment.html
