[gdal-dev] ogr2ogr and GPX files
Dylan Beaudette dylan.beaudette at gmail.com
Wed Mar 5 12:31:31 EST 2008
On Wednesday 05 March 2008, Tamas Szekeres wrote:
> Dylan,
> I couldn't reproduce the issue on Windows using the current version in
> the trunk. The result have been attached to this ticket.
> Are you sure you use the proper version?
> Best regards,
> Tamas
Maybe I am not using the latest GDAL?
> 2008/3/4, Dylan Beaudette <dylan.beaudette at gmail.com>:
> > On Tuesday 04 March 2008, Tamas Szekeres wrote:
> > > Dylan,
> >  > Would you attach this ogr2ogr commandline string and the corresponding
> >  > test data to
> >  > http://trac.osgeo.org/gdal/ticket/2171
> >  > I'll look into the problem than.
> >  > ( That's why I still haven't closed this ticket ;-)
> >  > Best regards,
> >  > Tamas
> > Thanks Tamas:
> >  http://trac.osgeo.org/gdal/ticket/2171#comment:5
> >  Cheers,
> >  Dylan
> >  > >  > Hi,
> >  > >  > Yes, you should try with the recent SVN version. The changes
> >  > >  > related to this issue are pretty new.
> >  > >  > Best regards,
> >  > >  > Tamas
> >  > > Hi Tamas,
> >  > >  Thanks for the tip. Unfortunately, even with today's SVN, I still
> >  > > get the same error:
> >  > >  ERROR 1: SQL: Missing comma after column cat in SELECT statement.
> >  > > Cheers,
> >  > >  Dylan
> >  > >  > > On Monday 03 March 2008, Even Rouault wrote:
> >  > >  > >  > In fact, using the same principle, you can use just one
> >  > >  > >  > command line and no intermediary file :
> >  > >  > >  > ogr2ogr -f GPX destination.gpx source.shp -sql "SELECT
> >  > >  > >  > src_field_1 AS name, src_field_2 AS desc FROM
> >  > >  > >  > your_source_layer_name"
> >  > >  > >  > Thanks to FrankW for the tip ;-)
> >  > >  > > Thanks Even / Frank.
> >  > >  > >  One small problem:
> >  > >  > >  ogr2ogr -t_srs '+proj=latlong +datum=WGS84' \
> >  > >  > >  -f GPX -dsco GPX_USE_EXTENSIONS=YES \
> >  > >  > > veg_points.gpx veg_points.shp \
> >  > >  > >  -sql "SELECT cat AS foo FROM veg_points"
> >  > >  > > statement.
> >  > >  > >  Could this be a bug or my version of GDAL too old ? This is
> >  > >  > > with GDAL SVN, checked out a couple of weeks ago.
> >  > >  > >  I get a valid GPX file if I do not use the "AS foo" operator.
> >  > >  > >  Ideas?
> >  > >  > >  Dylan
> >  > >  > >  > Le Monday 03 March 2008 19:43:12 Even Rouault, vous avez
écrit :
> >  > >  > >  > > Hi,
> >  > >  > >  > > I see your point...
> >  > >  > >  > > The solution is the powerful OGR Virtual Dataset format !
> >  > >  > >  > > See http://www.gdal.org/ogr/drv_vrt.html
> >  > >  > >  > > In fact, the documentation should probably be extended to
> >  > >  > >  > > demonstrate the power of the OGR SQL for that particular
> >  > >  > >  > > case
> >  > >  > >  > > Try to paste the following lines in a file
> >  > >  > >  > > (remapped_layer.vrt would be fine)
> >  > >  > >  > > <OGRVRTDataSource>
> >  > >  > >  > >     <OGRVRTLayer name="remapped_layer">
> >  > >  > >  > >         <SrcDataSource>your_source.shp</SrcDataSource>
> >  > >  > >  > >         <SrcSQL>SELECT src_field_1 AS name, src_field_2 AS
> >  > >  > >  > > desc FROM your_source_layer_name</SrcSQL>
> >  > >  > >  > >     </OGRVRTLayer>
> >  > >  > >  > > </OGRVRTDataSource>
> >  > >  > >  > > Replace your_source.shp, src_field_1, src_field_2 and
> >  > >  > >  > > your_source_layer_name by the appropriate values from your
> >  > >  > >  > > source dataset and 'ogrinfo -ro -al remapped_layer.vrt'
> >  > >  > >  > > should show a structure compatible of a GPX file.
> >  > >  > >  > > Best regards,
> >  > >  > >  > > Even
> >  > >  > >  > > Le Monday 03 March 2008 07:04:41 Dylan Beaudette, vous
> >  > >  > >  > > avez
> >  écrit :
> >  > >  > >  > > > Hi,
> >  > >  > >  > > > is there a simple approach (via ogr2ogr) to create GPS
> >  > >  > >  > > > files which have standard waypoint tags such as <name>,
> >  > >  > >  > > > <elev>, <cmt>, etc. by re-mapping columns in the
> >  > >  > >  > > > attribute table of the source vector?
> >  > >  > >  > > > for example:
> >  > >  > >  > > > # export points vector from GRASS
> >  > >  > >  > > > v.out.ogr in=wp type=point dsn=wp.shp
> >  > >  > >  > > > # convert tp GPX:
> >  > >  > >  > > > wp_gps.gpx wp.shp
> >  > >  > >  > > > This results in a working GPX waypoints file, that when
> >  > >  > >  > > > uploaded to a GPS is functional, but the waypoints are
> >  > >  > >  > > > all re-named sequentially. Note that I am uploading the
> >  > >  > >  > > > GPX file the GPS via gpsbabel.
> >  > >  > >  > > > Does anyone know of the appropriate incantation that one
> >  > >  > >  > > > could use to translate the column structure of the input
> >  > >  > >  > > > wp.shp (i.e. the stuff in its .dbf) into standard
> >  > >  > >  > > > waypoint tags?
> >  > >  > >  > > > thanks in advance!
> >  > >  > >  > > > PS: trying to write a simple tutorial for some
> >  > >  > >  > > > colleagues [1]
> >  > >  > >  > > > 1.
> >  > >  > >  > > > http://casoilresource.lawr.ucdavis.edu/drupal/node/553
> >  > >  > >  > > _______________________________________________
> >  > >  > >  > > gdal-dev mailing list
> >  > >  > >  > > gdal-dev at lists.osgeo.org
> >  > >  > >  > > http://lists.osgeo.org/mailman/listinfo/gdal-dev
> >  > >  > >  Dylan Beaudette
> >  > >  > >  Soil Resource Laboratory
> >  > >  > > University of California at Davis
> >  > >  > >  530.754.7341
> >  > > Dylan Beaudette
> >  > >  530.754.7341
> > Dylan Beaudette
> >  530.754.7341
Dylan Beaudette
530.754.7341
