[Gdal-dev] GDAL WMS Questions..
Fodder cryan at csse.com.au
Thu Mar 6 01:31:16 EST 2008
mchapman wrote:
> I think you just pass the file path of the XML file to the GDALOpen
> method.
> That's how the WMS client works.  Then just call RasterIO() and work with
> it
> the same way you would any other raster.  That is my guess anyway.
> Martin
Thanks, I tried this at first but when I pass the filepath to the GDALOpen
method I just get a nil object back (the code works for other images). I'm
just using the demo xml from the gdal.org site:
<GDAL_WMS>
    <Service name="TileService">
        <Version>1</Version>
<ServerUrl>http://s0.tileservice.worldwindcentral.com/getTile?</ServerUrl>
        <Dataset>za.johannesburg_2006_20cm</Dataset>
    </Service>
    <DataWindow>
        <UpperLeftX>-180.0</UpperLeftX>
        <UpperLeftY>90.0</UpperLeftY>
        <LowerRightX>180.0</LowerRightX>
        <LowerRightY>-90.0</LowerRightY>
        <SizeX>268435456</SizeX>
        <SizeY>134217728</SizeY>
        <TileLevel>19</TileLevel>
    </DataWindow>
    <Projection>EPSG:4326</Projection>
    <OverviewCount>16</OverviewCount>
    <BlockSizeX>512</BlockSizeX>
    <BlockSizeY>512</BlockSizeY>
    <BandsCount>3</BandsCount>
</GDAL_WMS>
View this message in context: http://www.nabble.com/GDAL-WMS-Questions..-tp15866625p15867346.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
