[gdal-dev] Polynomial warping ?
    Nicolas MERLET
    admin at merletn.org
    Thu Mar  6 07:31:44 EST 2008
Hi all,
I'm trying to transform an image using gdal_translate to add GCPs and
gdalwarp to apply GCPs.
I'm using a jpeg grid as a demonstration. With ArcGIS, in order 2, I get
this result :
http://dev.merletn.org/gis/arcgis.jpg
With the same GCPs, gdalwarp produces this result :
http://dev.merletn.org/gis/gdalwarp.jpg
Here my GPS :
http://dev.merletn.org/gis/grid-gcp.txt
For further information, you can see my batch file :
http://dev.merletn.org/gis/batch.txt
I can't understand why GDAL does not use an order 2 polynomial
transformation. Why does results are different from each others ?
Thank you very much for helping...
Regards, Nicolas
