[gdal-dev] Loading from a stream/memory rather than a file
Christiaan Janssen cjanssen at iavo-rs.com
Fri Mar 7 12:04:51 EST 2008
Does anyone know if it is possible to create/open an image with GDAL using a stream or chunk of memory instead of a file? This would be useful in writing a caching mechanism but also to do in memory and other non file based processing.
Christiaan
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20080307/280ca58a/attachment.html
