[Gdal-dev] GDAL WMS Questions..
Martin Chapman mchapman at texelinc.com
Sun Mar 9 21:55:48 EDT 2008
Fodder,
Run "gdalinfo --formats" in the bin directory.  If you don't see WMS then it
isn't compiled.  To get WMS support I think you need expat and curl.
See the following in the nmake.opt file in the gdal root directory:
# Uncomment to use libcurl (DLL by default)
# The cURL library is used for WCS, WMS, GeoJSON, SRS call importFromUrl(),
etc.
Martin
-----Original Message-----
[mailto:gdal-dev-bounces at lists.osgeo.org] On Behalf Of Fodder
Sent: Sunday, March 09, 2008 6:08 PM
To: gdal-dev at lists.osgeo.org
Subject: Re: [Gdal-dev] GDAL WMS Questions..
Adam Nowacki wrote:
> If you're getting null (0) and no error message then either you have no
> wms driver built in or the xml doesnt start with <GDAL_WMS>.
ok, well the xml does start with <GDAL_WMS>. I'm using the FWTools 2.06
package so I assume the WMS driver should be included, is there someway I
can check?
View this message in context:
http://www.nabble.com/GDAL-WMS-Questions..-tp15866625p15948582.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
gdal-dev mailing list
http://lists.osgeo.org/mailman/listinfo/gdal-dev
