[gdal-dev] Create occurance dataset
Clay, Bruce bclay at ball.com
Wed Mar 12 10:32:38 EDT 2008
I need to create an occurrence vector dataset from an existing point
dataset.  The original dataset is in GCS WGS84 so it does not lend it
self to finding all of the points within a 1 km cell.  The dataset is
worldwide coverage of MODIS fire data so projecting into a single UTM
zone won't work well either.  My current plan is to use OGR to transform
the WGS84 data into a projected worldwide spatial reference system.
Before I tackle this I wanted to know:
if there is already a built in method I have not found to "bin" (sort
into 1km cells) geospatial data and
if this method makes sense and
if someone has a fast algorithm to do the data bin operation
Any thoughts would be greatly appreciated.
Bruce
This message and any enclosures are intended only for the addressee.  Please
notify the sender by email if you are not the intended recipient.  If you are
not the intended recipient, you may not use, copy, disclose, or distribute this
message or its contents or enclosures to any other person and any such actions
may be unlawful.  Ball reserves the right to monitor and review all messages
and enclosures sent to or from this email address.
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20080312/de952aaa/attachment.html
