[gdal-dev] HDF5 1.8? DAP 3.8?
Lucena, Ivan ivan.lucena at pmldnet.com
Thu Mar 13 08:25:49 EDT 2008
Javier,
I believe that the configuration flag is H5_USE_16API.
Did you apply this flag to the HDF library or to the HDF5 driver in GDAL?
Best regards,
Ivan
Javier Urien wrote:
> I am using gdal with HDF5 1.8 and if you compile it so that it uses
> APIv1.6 (forgot the configure flag) it works fine.
