[gdal-dev] cannot open shape file created in linux in windows
gaffigan at sfos.uaf.edu gaffigan at sfos.uaf.edu
Tue Mar 18 04:02:32 EDT 2008
Xiaodong,
Good morning.  I'm not sure why the example wouldn't work on your machine.
 When I paste the lines below into my linux terminal window, I get the
result shown on the csv driver page.  I tried the example without error on
a number of machines, with GDAL versions ranging from 1.5.0 to 1.3.1.  You
could confirm that the VRT driver is enabled, but I thought it always is.
  ogrinfo --formats     # look for "VRT"
Steve
cat > test.csv <<EOF
Latitude,Longitude,Name
48.1,0.25,"First point"
49.2,1.1,"Second point"
47.5,0.75,"Third point"
EOF
cat > test.vrt <<EOF
<OGRVRTDataSource>
    <OGRVRTLayer name="test">
        <SrcDataSource>test.csv</SrcDataSource>
        <GeometryType>wkbPoint</GeometryType>
        <LayerSRS>WGS84</LayerSRS>
        <GeometryField encoding="PointFromColumns" x="Longitude"
y="Latitude"/>
    </OGRVRTLayer>
</OGRVRTDataSource>
EOF
ogrinfo -ro -al test.vrt
> Hello Steve,
> Thanks for offering help. Trying
> ogr2ogr -f "ESRI Shapefile" grid.shp grid.vrt -nlt multipoint
> I got error message, saying 'Unable to open data source grid.vrt with
> the following drivers', followed by a list of drivers, including ESRI
> Shapefile, CSV, among others.
> Actually, I got the same error message when running ogrinfo -ro -al
> test.vrt, using the exact same example listed in the page you referred to,
> http://www.gdal.org/ogr/drv_csv.html
> Any idea?
> Xiaodong
> gaffigan at sfos.uaf.edu wrote:
>> Hello.  You might try the following:
>> The important part is that the source dataset is the vrt definition
>> file,
>> not the csv data file.  See http://www.gdal.org/ogr/drv_csv.html.
>> Hopefully it's this easy.
>> Steve
>>> Hi,
>>> I used --- ogr2ogr -f "ESRI Shapefile" grid grid.csv -nlt multipoint
>> ----- to convert a series of points (in csv format) into a shape file of
>> multiple points. I also have a grid.vrt and a grid.csvt file that are
>> used in this conversion. A directory named grid was created and under it
>> there are 3 files, namely, grid.shp, grid.dbf, and grid.shx. Using
>> ogrinfo grid returns,
>>> INFO: Open of 'grid', using driver 'ESRI Shapefile" successful. 1:grid
>> (multi point).
>>> Also using ogrinfo -ro -al grid returns a series of records, and the
>> last one is
>>> OGRFeature (grid): 5374
>>> long (Real) = -100.08310911830001
>>> lat (Real) = 44.963133226799997
>>> data (Real) = 3
>>> mapped dat (Real) = 68.000000000
>>> The above commands were executed in Linux with gdal installed. After
>> transferring grid folder to windows, I can open them, but nothing show
>> up (I tried ENVI and FWTool). For example, in FWTool, it seemed that the
>> shape file can be opened, but this is what showed in the Shape
>>> Attributes window,
>>> Where did I do wrong?
>>> Thanks
>>> Xiaodong
>>> gdal-dev mailing list
>>> gdal-dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
