[gdal-dev] Problem with pct2rgb.py
Jean-Claude Repetto jrepetto at free.fr
Tue Mar 18 07:58:18 EDT 2008
Hello,
I have downloaded a map of Corsica at
<http://www.ign.fr/telechargement/MPro/produit/SCANS/SCAN1000_Corse_L2E.zip>
Now, I want to convert it with gdal_translate. As it uses a palette, I
first need to convert it to RGB.
Usually, I use ImageMagick for that, but this time I decided to give a
try to pct2rgb.py.
$ pct2rgb.py COR_0000.TIF COR_0000_64K.TIF
0Traceback (most recent call last):
   File "/usr/bin/pct2rgb.py", line 162, in ?
     tif_ds.GetRasterBand(iBand+1).WriteArray(dst_data,0,iY)
   File "/usr/lib64/python2.4/site-packages/gdal.py", line 796, in
WriteArray
   File "usr/lib64/python2.4/site-packages/osgeo/gdal_array.py", line
157, in BandWriteArray
ValueError: array does not have corresponding GDAL data type
Imagemagick gives some warnings, but the result seems correct :
$ convert COR_0000.TIF -type TrueColor COR_0000_64K.TIF
convert: COR_0000.TIF: unknown field with tag 33550 (0x830e)
encountered. `TIFFReadDirectory'.
convert: COR_0000.TIF: unknown field with tag 33922 (0x8482)
convert: COR_0000.TIF: unknown field with tag 34735 (0x87af)
convert: COR_0000.TIF: unknown field with tag 34737 (0x87b1)
I don't understand what's wrong, any help would be appreciated.
Thanks,
Jean-Claude
