[Gdal-dev] Clip raster by percentage?
Tue Mar 18 09:54:20 EDT 2008
Pål Kristensen wrote:
> Hi!
> I it possible to clip a GeoTiff by a given percentage from each side (ie 5%
> from top, 2% from bottom, and so on) with GDAL, and if so, how is it done?
Pål,
This is not directly provided for - no.   You would basically need to figure
out what pixel-line window it amounts to and use that with gdal_translate and
the -srcwin switch.
For example for a 1000x1000 image you might use:
   gdal_translate -srcwin 50 50 930 930 in.tif out.tif
would be 5% off the top and left, and 2% off the right and bottom.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
