[gdal-dev] Extracting MODIS bands from MODIS HDF grid file using gdalwarp fails on 64-bit system (?)
Tue Mar 18 11:19:39 EDT 2008
Nikos Alexandris wrote:
> Dear gdal-list,
> in the past I successfully used the following lines from
> Markus' (Neteler) script to extract MODIS bands from MOD09 products
> (surface reflectance).
> FILE=$1
> HDFlayerNAMES="`gdalinfo $FILE | grep SUBDATASET_ | grep _NAME | cut
> -d'=' -f2`"
> for i in ${HDFlayerNAMES} ; do
> 	INPUT="`echo ${i}`"
>         NEWNAME="`echo ${i} | cut -d':' -f4,5 | tr ':' '_' | tr -s '|'
> '_'`"
>         # apply GCPs and convert to GTiFF using -rcs
>         gdalwarp -s_srs '+proj=sinu +R=6371007.181 +nadgrids=@null
> +wktext' -t_srs '+init=epsg:2100' -tr 500 500 -rcs "${INPUT}"
> $NEWNAME.HGRS87.tif
> Since I switched to (Ubuntu 7.10) 64-bit I have problems reading /
> writing HDF grid files.
> The result, when running the above lines in a script with a
> MOD09????.HDF file, is:
> Creating output file that is 2772P x 2333L.
> Processing input file
> HDF4_EOS:EOS_GRID:"MOD09GHK.A2006239.h19v05.004.2006241155729.hdf":MOD_Grid_L2g_2d:sur_refl_b01_1.
> Using internal nodata values (eg. 144) for image
> ERROR 1: GDreadfield() failed for block.
> ERROR 1: IReadBlock failed at X offset 0, Y offset 1
> ERROR 1: GetBlockRef failed at X block offset 0, Y block offset 1
> HDF4_EOS:EOS_GRID:"MOD09GHK.A2006239.h19v05.004.2006241155729.hdf":MOD_Grid_L2g_2d:sur_refl_b02_1.
> Is it really a  64-bit problem or is something in my systems
> configuration? I've had problems understanding and applying variables,
> shared libraries. But I think I've corrected this.
Nikos,
I have not encountered problems with HDF4 on Ubuntu 64 bit but I build
my HDF4 and GDAL libraries from source.  I would encourage you to file
a quite specific ticket on the issue.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
