[gdal-dev] Re: gdalwarp -co COMPRESSION issues
Matt Wilkie matt.wilkie at gov.yk.ca
Wed Mar 19 13:23:29 EDT 2008
 > ...Here they go again:
 > http://trac.osgeo.org/gdal/ticket/1688
 > http://trac.osgeo.org/gdal/ticket/1689
I first noticed compression problems with gdalwarp about gdal 1.4.0, and
filed ticket http://trac.osgeo.org/gdal/ticket/1470, which was fixed.
Perhaps there is something in that change which could help here.
If not and fixing the problem is as difficult as Even and Frank surmise
(more likely), then I suggest that to avoid confusing people the
compress option be dropped from gdalwarp for now, or at least issue a
warning when used.
It might also be fruitful if Even's extended description for why this
bug won't be addressed soon is posted to one of the ticket numbers above.
best regards,
matt wilkie
Geographic Information,
Information Management and Technology,
Yukon Department of Environment
10 Burns Road * Whitehorse, Yukon * Y1A 4Y9
867-667-8133 Tel * 867-393-7003 Fax
http://environmentyukon.gov.yk.ca/geomatics/
