[gdal-dev] RE: compile from source on Ubuntu7.10 64bit EC2 instance
Randy George rkgeorge at cadmaps.com
Thu Mar 20 13:15:41 EDT 2008
Hi Nikos,
	Here is the list:
# gdalinfo --formats
Supported Formats:
  VRT (rw+): Virtual Raster
  GTiff (rw+): GeoTIFF
  NITF (rw+): National Imagery Transmission Format
  RPFTOC (ro): Raster Product Format TOC format
  HFA (rw+): Erdas Imagine Images (.img)
  SAR_CEOS (ro): CEOS SAR Image
  CEOS (ro): CEOS Image
  JAXAPALSAR (ro): JAXA PALSAR Product Reader (Level 1.1/1.5)
  GFF (ro): Ground-based SAR Applications Testbed File Format (.gff)
  ELAS (rw+): ELAS
  AIG (ro): Arc/Info Binary Grid
  AAIGrid (rw): Arc/Info ASCII Grid
  SDTS (ro): SDTS Raster
  DTED (rw): DTED Elevation Raster
  PNG (rw): Portable Network Graphics
  JPEG (rw): JPEG JFIF
  MEM (rw+): In Memory Raster
  JDEM (ro): Japanese DEM (.mem)
  GIF (rw): Graphics Interchange Format (.gif)
  ESAT (ro): Envisat Image Format
  BSB (ro): Maptech BSB Nautical Charts
  XPM (rw): X11 PixMap Format
  BMP (rw+): MS Windows Device Independent Bitmap
  DIMAP (ro): SPOT DIMAP
  AirSAR (ro): AirSAR Polarimetric Image
  RS2 (ro): RadarSat 2 XML Product
  PCIDSK (rw+): PCIDSK Database File
  PCRaster (rw): PCRaster Raster File
  ILWIS (rw+): ILWIS Raster Map
  SGI (ro): SGI Image File Format 1.0
  SRTMHGT (rw): SRTMHGT File Format
  Leveller (rw+): Leveller heightfield
  Terragen (rw+): Terragen heightfield
  PNM (rw+): Portable Pixmap Format (netpbm)
  DOQ1 (ro): USGS DOQ (Old Style)
  DOQ2 (ro): USGS DOQ (New Style)
  ENVI (rw+): ENVI .hdr Labelled
  EHdr (rw+): ESRI .hdr Labelled
  GenBin (ro): Generic Binary (.hdr Labelled)
  PAux (rw+): PCI .aux Labelled
  MFF (rw+): Vexcel MFF Raster
  MFF2 (rw+): Vexcel MFF2 (HKV) Raster
  FujiBAS (ro): Fuji BAS Scanner Image
  GSC (ro): GSC Geogrid
  FAST (ro): EOSAT FAST Format
  BT (rw+): VTP .bt (Binary Terrain) 1.3 Format
  LAN (ro): Erdas .LAN/.GIS
  CPG (ro): Convair PolGASP
  IDA (rw+): Image Data and Analysis
  NDF (ro): NLAPS Data Format
  DIPEx (ro): DIPEx
  ISIS3 (ro): USGS Astrogeology ISIS cube (Version 3)
  ISIS2 (ro): USGS Astrogeology ISIS cube (Version 2)
  PDS (ro): NASA Planetary Data System
  ERS (rw+): ERMapper .ers Labelled
  L1B (ro): NOAA Polar Orbiter Level 1b Data Set
  FIT (rw): FIT Image
  RMF (rw+): Raster Matrix Format
  RST (rw+): Idrisi Raster A.1
  INGR (rw+): Intergraph Raster
  GSAG (rw+): Golden Software ASCII Grid (.grd)
  GSBG (rw+): Golden Software Binary Grid (.grd)
  GS7BG (ro): Golden Software 7 Binary Grid (.grd)
  COSAR (ro): COSAR Annotated Binary Matrix (TerraSAR-X)
  TSX (ro): TerraSAR-X Product
  COASP (ro): DRDC COASP SAR Processor Raster
  RIK (ro): Swedish Grid RIK (.rik)
  USGSDEM (rw): USGS Optional ASCII DEM (and CDED)
  GXF (ro): GeoSoft Grid Exchange Format
  ADRG (rw+): ARC Digitized Raster Graphics
# ogrinfo --formats
Supported Formats:
  -> "ESRI Shapefile" (read/write)
  -> "MapInfo File" (read/write)
  -> "UK .NTF" (readonly)
  -> "SDTS" (readonly)
  -> "TIGER" (read/write)
  -> "S57" (read/write)
  -> "DGN" (read/write)
  -> "VRT" (readonly)
  -> "REC" (readonly)
  -> "Memory" (read/write)
  -> "BNA" (read/write)
  -> "CSV" (read/write)
  -> "GML" (read/write)
  -> "GPX" (read/write)
  -> "KML" (read/write)
  -> "GeoJSON" (read/write)
  -> "GMT" (read/write)
  -> "AVCBin" (readonly)
Randy
-----Original Message-----
From: Nikos Alexandris [mailto:nikos.alexandris at felis.uni-freiburg.de]
Sent: Thursday, March 20, 2008 10:37 AM
To: rkgeorge at cadmaps.com
Cc: gdal-dev at lists.osgeo.org
Subject: Re: [gdal-dev] RE: compile from source on Ubuntu7.10 64bit EC2
instance
On Thu, 2008-03-20 at 09:50 -0600, Randy George wrote:
> Hi Adam, Markus,
> Thanks for stretching the rules a bit. This helped immensely.
> For the next Ubuntu EC2 novice:
>  cd /usr/src
>  apt-get update
>  apt-get install build-essential
>  wget http://download.osgeo.org/gdal/gdal-1.5.0.tar.gz
>  tar -xvzf gdal-1.5.0.tar.gz
>  cd gdal-1.5.0
>  ./configure
>  make
>  make install
>  ldconfig
>  gdal_grid --version
>    GDAL 1.5.0, released 2007/12/18
> thanks
> randy
Hi Randy!
Do you mind sharing you gdalinfo --formats and ogrinfo --formats ?
Cheers and thanks,
Nikos
