[gdal-dev] FlushCache and SyncToDisk
Mon Mar 24 13:11:00 EDT 2008
Ari Jolma wrote:
> Frank,
> I may have wondered and asked this before but anyway. Why don't the
> dataset and layer destructors check, if they were opened as update and
> call FlushCache or SyncToDisk in the destructor?
> I thought about adding this into the wrappers but eAccess is a protected
> member of GDALDataset for example.
Ari,
All driver implementations are supposed to flush to disk when the
datasource/dataset is destroyed.  If they don't, it is a bug in the
driver implementation and should (IMHO) be addressed there.
A problem I think we have had sometimes in the swig bindings is
that confusion about reference counting has resulted in the
datasource/dataset objects not being properly destroyed.  But I
think we also need to solve the root of this problem (if it still
exists), not work around the symptoms.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
