[gdal-dev] GDALDriver::CopyFiles
Mon Mar 24 14:56:32 EDT 2008
Limei Ran wrote:
> Hi:
> I am using GDALDriver::CopyFiles in our cpp program to copy an image
> file in HFA format.  But, the old file has three file list:
> File list 0 =
> /nas/uncch/depts/cep/emc/lran/nlcd2001/nlcd/landcover1_3k_022007.img
> File list 1 =
> /nas/uncch/depts/cep/emc/lran/nlcd2001/nlcd/landcover1_3k_022007.img.aux.xml
> File list 2 =
> /nas/uncch/depts/cep/emc/lran/nlcd2001/nlcd/landcover1_3k_022007.rrd
> CopyFiles failed with error:
> ERROR 1: Unable to rename fileset due irregular basenames.
> I found that it was failed in CPLGetBasename function due to
> landcover1_3k_022007.img.aux.xml file name. Does GDAL use
> landcover1_3k_022007.img.aux.xml file?  Or, Can I delete it?
Limei,
GDAL does consult the .aux.xml file (which is actually created by
GDAL!) and it ought to be able to copy it.  If not, please file a
ticket on the issue and I'll try to get it fixed for 1.5.2.  In the
meantime you can likely live without the .aux.xml file as a workaround.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
