[gdal-dev] Problem with gdal_translate : Illegal band #
Jean-Claude Repetto jrepetto at free.fr
Tue Mar 25 05:38:19 EDT 2008
Hello,
I have downloaded a map of Corsica at
<http://www.ign.fr/telechargement/MPro/produit/SCANS/SCAN1000_Corse_L2E.zip>
Now, I want to convert it to ECW with gdal_translate. As it uses a
palette, I first need to convert it to RGB.
mv COR_0000.TIF COR_0000.TIF.orig
pct2rgb.py COR_0000.TIF.orig COR_0000.TIF
gdal_translate -of ECW -co "TARGET=88" -co "DATUM=NTF"  -co
"PROJ=LM2FRANC"  -co "LARGE_OK=YES" COR_0000.TIF COR_0000.ecw
Input file size is 1200, 2200
Warning 6: '88' is an unexpected value for TARGET creation option of
type float.
0...10...20...30...40...50...60...70...80...90...100 - done.
ERROR 5: GDALDataset::GetRasterBand(2) - Illegal band #
ERROR 5: GDALDataset::GetRasterBand(3) - Illegal band #
The ECW file is created, but it contains garbage.
At this time, if I execute the same command again :
type float.
It works and the ECW file is correct. If I delete the ECW file and
launch the same command, the errors come back.
I am using GDAL 1.5.0.
Any idea ?
Thanks,
Jean-Claude
