[gdal-dev] object methods for adding metadata to Geotiff
Tue Mar 25 18:26:16 EDT 2008
Matt Fearon wrote:
> Hi,
> I am trying to assign projection information and other metadata to a
> converted Geotiff file via osr.SpatialReference. My original raw
> binary file has this information separate from the data. I would like
> to attach this information to the new Geotiff using python/GDAL. I am
> able to input a subset of projection information with the following
> object methods. However, how could I add information on pixel size and
> corner coordinates and other metadata? Is there an object method
> though python for doing this - or would have to use the gdal_translate
> utility?
Matt,
You should use the SetGeoTransform() method on the dataset to set the
origin and pixel size.  For instance for an image with the top left
corner at 250000mN, 3730000mE and a pixel size of 10m x 10m I would
use:
  dst_ds.SetGeoTransform( (250000,10,0,3730000,0,-10) )
Read up on the GDAL data model for more detail on the geotransform if
you are interested.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
