[gdal-dev] NODATA value in an array from RasterIO
Wed Mar 26 10:04:09 EDT 2008
Limei Ran wrote:
> Hi Frank:
> I used:
> int pbHaveNoData;
> double fNoData = poBand->GetNoDataValue( &pbHaveNoData );
> I got:
> pbHaveNoData = 0;
> fNoData =  -10000000000.000000
> The image is GByte image.  Does it mean the image does not have nodata
> value since pbHaveNoData = 0?
Limei,
That is correct.  The GDAL driver is unaware of any nodata value.
 > I viewed the image in arcGIS, it has a
> lot of nodata value areas.  How can I update the image by assigning some
> pixels to NODATA based on some conditions?
If you see a particular pixel value that is a nodata value, you can use
the poBand->SetNoDataValue() method to mark that value as being nodata.
Note that many drivers will not support this change, so check the image
afterwards with gdalinfo to see if the change had an effect.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
